Hi,
Im new here ( name's Max) and saw a need to join up as my wife has had her TJ VRX for the past 17 years which she loves ( clicked over 270 K last week). It's been my responsibilty to look after / baby / service / repair it all these years which I do with pleasure as you all know they are a great car and even today I think they hold their own - genuinely a pleasure to drive.
Anyway enough of the Banter. Recently it has developed a pronounced misfire at low revs under accelaration which seems to peter out up the rev range but still is holding back on its usual sweet linear power band. No issues on starting or idling. Last year I replaced the fuel pump. Recently ( last week ) changed the fuel & air filters with the usual 5K oil and filter change - still misfiring but she says less so. So im thinking maybe 3 areas:
1. injectors ( get them cleaned)
2. plugs ( both banks) / leads / coil / distributor
3. Vacuum line
She says that the engine light did come on a few months back but only made a brief appearance and has not come on since.
My plan of attack is to:
1. lift off the intake plenum & clean the injectors ( need to replace the rocker cover gasket underneath it)
2. at the same time replace both spark plug banks ( due anyway)
3. replace the leads / distributor cap / rotor
Another issue is that it has started burning oil ( 0.5 litre per 5000 k's) which leads me to believe valve stem seals . Im thinking maybe a reason for misfire?? ( fouling plugs or other complications leading to misfire)
So im also thinking at same time while everything is off to replace the valve stem seals - thoughts??
Any help / advice / pointers appreciated.
Ciao.
